AWDisuzu said:mmmmm booooost
hey Mike! thinking about gettin real drunk tonight and turning up from 6 psi to twenty, whatch think?
AWDisuzu said:with race gas, and some stronger rods, you should be set! that would make 1200 hp
AWDisuzu said:the sts does the same thing a pazton does, creates boost. I'd add a 2nd wastegate, big FMIC, and I'd tune it myself of course since blowing engines isn't fun. I'd also do all my tuning with 118 octaine (c-16) race gas to elliminate any detonation problems
good luck!
FlyingLow said:I don't think the problem is just the boost. I have racked my brain on this thing. First we had the overboost problem. That has been fixed. Second we had the fact that STS-1E (mini VEC2) went out with no program loaded with caused a lean out. Now the problem is the fuel management. The controller that comes with the current system (If is still comes with it) only controlls the the 4 extra injectors. So there is no way to meter the fuel to a specific cylinder. Since the #3 seems to run hotter then the others it is the first one to fail due to lean out. Dropping the extra injectors and going with larger ones in place of the stock ones will greatly benifit this system. Along with Meth and a VEC3 to control it all. I mean after all boost is boost right? Hell I don't know. Forced air coming in should be the same right? So if there is an issue then it either has to be the amount of air, temp of the air or the amount of fuel mixed with the air. I believe my engine is still surving because of the amount of fuel I'm sending to the cylinders. I believe that is the only thing that has saved me. So if anyone thinking of the STS kit go ahead and add larger injectors, meth kit and a VEC3 to your list. I do know that STS realized that there was a problem with the fuel and tried to correct it. I do believe that is why the price of the kit dropped as they no longer sell the STS-1E. I'm not postive on that as it is still on their web page.
Stinker, do twin alternators really cost that much?!jsut drop a ton of $ and do this
yipBone said:Sean Roe stopped selling the STS, what does that tell you?!
That is the best looking 14 second motor I've ever seen in my life.Stinker said:jsut drop a ton of $ and do this
AWDisuzu said:supplemental injectors are a bad idea ALWAYS!
at the very least, use a FMU to increase the fuel pressure (in relation to boost) to over 100psi on stock injectors.
or, bigger injectors and standalone computer.
UNIBOY said:That is the best looking 14 second motor I've ever seen in my life.![]()
I hope to see it in person one day.Stinker said:why thank you kind sirmore to come very soon
UNIBOY said:I hope to see it in person one day.![]()
Silverback said:The one thing you are forgetting is the back pressure and the additional heat that is retained in the engine as a result of that back pressure.
Dave T(BADVENM) said:there was much discussion going on with Joe and I and Justin and Sean Roe after joe learned and wasnt prepared for my fmu and fuel pressure setup. He was worried initially about blowing off the fuel lines and that he'd have to increase the injectors, which would require quite a bit of work on a limited time to do it. I forget the details but he was able to disconnect some stuff on the split second box and tee into something in order to use the fmu, keeping the stock injectors in tact. sean roe had already come across this issue and had the answer to our questions within minutes. thanks again sean roe and joe.
Joe doesnt give up easily...thats good because early on it didnt look like he'd be able to do anything with the setup I had.
FlyingLow said:When is the back pressure present? Those that lost an engine did so mostly during times when the turbo was making boost. Wouldn't the back pressure be very low under boost? When would the pressure be the highest? The heat that is retained could be reduced greatly with either Meth or an inter-cooler.
Begood said:I think the bottom line is, go Roe, or Paxton, but NOT STS!
Bill.
