ARRESTmeRed04
now if i could just find a cheap sts setup, or just wait for a few of the blower guys to switch over and sell their setup's cheap....
msdnga said:Merritt Island? Man I am all over there in the Procharged Ram on Fridays...
Brat said:To the owners Mr.Fstjack,Patrick please make Marty a vender,the man has a lot to offer us here,you will not be sorry.He is a stand up guy and will only bring good things to the site.I will personlly stand behind him and put my reputation on the line as a member here.
msdnga said:I run 9 lb springs doubled, the 3 and 5 can be used also.
You reference the boost for the Tials directly from the compressor. There are two wastegates so accuracy is tight. If you put in your 5psi spring on both and reference the lower port of the WG, You will see 5psi, add the top port to the same line and you'll have 10. If you had one wastegate, overboost would be an issue with that combo size.
I can part throttle boost the truck, automatic or stick, over rev with street tires, safely without any overboost issues. Every single person that has come in for overboost issues, had either the signals or the springs wrong. It tells you right in the kits exactly how to set them up for 5 psi.
