The SC has shipped. I should have it in hand on Monday, and it is scheduled for installation starting Tuesday.
tinygiants said:I am holding off on them, till I prove I need them.
I guess I would really like to get the new axle instead.
Nowwhat said:Hey Dale...
while the truck is down for the SC install....beef up the trans....you are going to be bummed when you get your truck back after weeks of install time only to have to take it back for a slippin tranny.....Yes the trans will hold for a while...but I lost mine while drivin down the freeway....
tinygiants said:The SC has shipped. I should have it in hand on Monday, and it is scheduled for installation starting Tuesday.
Cablefed said:Auto maybe different due to the size of the tranny and access due to size.
tinygiants said:How do you guys hold back the inner manifold to midpipe bolt? I can not get to it with anything. I removed the wheel and inner liner. That made the outer 2 easy, but that last one is a tuff one.
tinygiants said:Mid Pipe and Cat Back Review:
The sound: Oh My Goodness. It has a nice rumble at idle. There is a very noticiable drone at a certain point in the RPM band. It is overbearing. I may seek to add a resonator like Prof (Roy) did.
tinygiants said:I could not get my cutting wheel on it, so I ground the head of the bolt off.
I need to go get a clamp, and work on a joint or two, then it is done.
Side note, I noticed 2 hoses in the front right that are leaking some sort of oil. Are these the hoses that Prof and MarcT both had leak? I hope the dealer plays nice. We will see on Monday.
