I got my truck back in to the installer. He installed all of the covers and such that we left out to check for leaks. We also got the body work done from the install mishap. I was sad that they dented it, but I can not see any of the repair. They did a good job of matching.
I also got the dyno files for ROE. There was not a measureable difference (about 10hp) between meth and non meth. I topped out at the same number as last time. When I ran the tune from last time, it was a little lower than before. Not much.
I looked over all of the files, and I have to believe that dyno numbers are statistical nightmare. With the same tune, run back to back, you will see some variation in the outcome. This number ranges by about 5-10 hp before the heat soak. At heat soak, it becomes quite pronounced.
So overall i saw numbers a little lower than last week on the same tune. With meth, I equaled my previous tune (489hp). We will now see what Sean Roe can get out of it. Maybe I need headers.
The next test and tune is 7-6-07, so I will plan to make that one. I tried to go Friday, but I got there to late after getting it from the shop. So my first track run will be on the new tranny and hopefully on the custom tune.
