moparracing
it's purely a guess what your hp is @ the flywheel........ no 2 engines have the same hp....... put it on a dyno (rear wheel) & you will know what you've got.TNVIPER said:Huh?........
Absolutely but an estimation for those not near a dyno is suffice in must topics. I wasn't stating fact merely offering some digits on where mine would roughly be sitting for the sake of the topic and my question at hand.moparracing said:i saw that.......
my point being that stating a guess on modifications "@ the flywheel" would be better dynoing @ the rear wheels since that's the only semi-accurate way to do it @ this point.......
yellowfever#154 said:To back all this up a little bit there wasnt any problems with the VEC or the tunes. The tunes were sent to me from ROE for my application and were not altered, yet. We were just trying to alter them and werent able to. The truck ran a little leaner than we would have liked with the base tune, we then put in a different tune and different gas and then it came apart. I guess what I am trying to say is that I dont think it was the tuner or the VEC's fault. I think my earlier post of the VEC problem has stirred the pot a little here and maybe I should have worded it a little different. It would have been more like, how do I alter a tune and write it into the memory of the VEC. Rather than Im having a problem with the VEC.
TNVIPER said:Whoa..were the weights separating a cause to engine failure...a result of or nothing to do with.?..at any rate has anyone else found these weights separated?
yellowfever#154 said:Heres some pictures, hopefully the links work.
http://i246.photobucket.com/albums/gg115/stroked401/IMG_5068.jpg
http://i246.photobucket.com/albums/gg115/stroked401/IMG_5067.jpg
You can see where the 3 were sitting, not sure why it came apart.
FerrariTruck said:Is it a possibility that the input shaft of the trans maybe caught on the clutch as you were removing it? I really hope we dont have centerforce clutch issues
yellowfever#154 said:I think I learned today why I lost my engine. I sold my VEC and then it was sold again and ended up with Bone. He then sent it to Sean for testing and heres what was found:
The box settings on your VEC 3 were set incorrectly, but fixed now. Quote from Sean:
The VEC3 was set to look at AN4 for IAT ....didn’t have an AN4 input and voltage could bleed through without anything connected, causing the VEC3 to either add or subtract fuel arbitrarily.
Yellow venom said:Man,Now that really sux Tyler!! Good thing Bone got it looked at an the problem fixed before it ate another one!
Was that VEC # on Diebs engine too??
blackviper said:Wow. That really sucks. I think it's been discussed on the forum somewhere before the importance of have the correct box settings on the VEC3.
