Has anyone tried softening up the rear suspension (removing a leaf or three) to see if their truck hooks better?
I pulled 2 leafs from mine. Seems better but no #'s to back it up yet.
Curious on what springs you pulled?
I am thinking of trying a set of Pro-Comp bolt on ladder bars and was thinking of pulling a leaf or two!
One of the cheapest traction mods is tire sidewall, get some 305/45s (not 40s),
This is excellent advice, Carl! But, where you when I ordered new tires a week ago!? :banghead:
I'll let you know what leafs I decide to pull here in the next few weeks. Do you have a link to the ProComp bars? I am curious to see what they look like:
If you remove leafs you will encounter worse axle wrap than we already have!! DO NOT DO IT!!! Check this video of how our axle wraps and this is with an auto
https://www.youtube.com/watch?v=iOs6tAPQJ0k
ANY QUESTIONS?? Ask Troy about his S-Shaped springs![]()
Thats a kewl vid with a birds eye insight of exactly whats going on with axel and springs!!
Curiosity question,what if you were to take the truck to a spring shop and get one of those spring straps put around the bottom helper spring and the whole spring pack on the back side of axel and leave the front of springs??? Just a thaught????
Clamping the springs is an old trick that does indeed work. It allows the springs to stay together rather than fan out and wrap.:rock:
We still need a better solution and I am working on one as we speak.:rock:
