ARRESTmeRed04
We already know Dan can't measure anyways.....
I thought that was only when he was trying to drum up business...
What are the next weight reduction mods?
I can fully appreciate the effort in the weight reduction exercise. However, the minimal loss in weight by removing aerodynamic components will hurt your trap speeds and them some.
The large under chin (just behind splitter) plastic tray is HUGE! You want the air that is split at the lower edge of the bumper to flow as smooth as possible under the vehicle. Now you will encounter dirty eddie currents that will increase drag.
I would also recommend reinstalling any air management parts like the brake cooling ducts. Unless you plan on completely blocking off the holes left by removing them. The goal is to MINIMIZE airflow through the front of the truck. Any wasted air through the bumper or grill will slow you down with eddie currents and "Parachute effect".
Find the pictures of Trainmans front end. He is very smart about using additional lightweight plexiglass to block off any additional airflow through his front end. The aero advantage in the quarter and beyond is more beneficial than the weightloss.
Cheers and GLW project!!:rock:
Here is a link. The first page has the images I mentioned above...
http://www.vtcoa.com/forums/f11/new-personal-best-famoso-11-5-2011-a-50812/
Once the weight is moving above 40 M.P.H. Aerodynamics start to become more of a factor. Once your speed has doubled to 80 M.P.H. Your aero load has cubed! These trucks have really great and sneaky little add-on's from the Dodge NASCAR team that help this brick move trough the air.
Rock on Brother!!:rock:
My goal is to make ANY mod that is effective without disturbing to overall stock look of the truck. If so, I want it reversable.
Your project is interesting to me.....
I'm a little surprised you removed the sub. Not much of a music listener?
I am in my daily drivers, but I'd rather listen to the exhaust when I drive the truck. If I decide to put it back in it's a quick under 5 minute reinstall. :rock:
Makes sense. I didn't realize the '10 wasn't your daily.
