mopar-or-no-car
What minimal air goes into the scoop at higher speeds only gives a little more volume to the intake charge.
Then why not just leave the scoop open to lower under hood temps as it was designed to do!!
There are ways...to be smart with money...but since we're talking about the Volant.....I got mine used for a very low price....and the original poster of this thread bought his truck with the Volant already on....so it didn't cost him anything. Ray Webb gained 3 mph in the 1/4 mile, I have consistently ran faster than nearly every NA truck on this site.....even before I did any weight reduction, which shows it works for the two of us. You apparently don't have one, or have never tried one, have never posted a 1/4 time or speed to prove or disprove how bad the Volant is or how good whatever system you think is better. I have reported real world results hundreds of times on here with my times....and as of yet....nothing concrete from you. So show me the hard data....otherwise you're just offereing an opinion:dontknow:
The difference in engine temp withe the scoop blocked is not any higher than without it. Soi think the cooling effect if any is minimal at the very least
:dontknow:I'll be in the 10's with a stock box by the end of the year hopefully. Just won't be NA any more:chain:
Fixed it for you.![]()
With all due respect, you could gain 3 mph with the volant tho!!
:date:
Ram Air / Cold Air......
The factory system for cold air feed works very well.
(1) The primary secret to "Ram Air" is to SLOW DOWN the cool air. By putting a "scoop" pushing air strait into the box defeats any amount of ram recovery. Air under high velocity has LOW volume.
(2) The size of the opening is NOT relevant to the ram air pressure produced. It is only relevant to the AMOUNT of air that will flow into the opening at that pressure. Ram pressure is dependent only on air density and speed.
The factory scoop (in the grill block off) takes the high velocity, low volume air and "recovers" pressure with volume by allowing the incomming air to the fender to expand and fill the "box". The filled box has higher volume and pressure than whats comming in via the grill scoop. Just think about hydrodynamics. You have all done it with a garden hose. Turn on the water full and let it flow into a barrel. Now take your thumb and patially block the end. You have more water velocity, but lower volume and thus the barrel will fill slower.
The engine then draws from the cool, positive "box" fender chamber. If you have ever looked closely at a removed fender, the factory guys put a sound deadend baffle mid fender to help determine "box" volume. This area, even though it is not completely sealed can achive pressure equal to ambient at speeds as low as 40 m.p.h. As a test, I will eventually install a pressure sensor from a ram-air motorcycle to help determine at what speeds the fender "box" area starts to produce (if any) positive (above ambient) pressures. I would not be suprised to see over ambient by 120 m.p.h. However, the huge benefits of the fender area filling with cool, charged air equal to ambient are realized at the engines intake hole before the filter.
However, Ramming air strait in would yield the opposite result. Cool air in... Yes. Additional volume or positive charge....No. See the Primary rule above.
Our hood scoop also has aerodynamic benefits. In addition to the engine bay heat escaping, it also minimizes the "Parachute Effect" of the airflow into the engine bay from between the grill block offs. This "vent" in our hoods has a three fold benefit... Evacuates heat, reduces drag and assists front end downforce from the splitter.
This is why I would not use a Volant or the Mopar CAI systems.
Cheers Guys!!
So this is opinion or actually has facts to support it?
Hey mopar or no car I don't work on my shit either so I'm a sissy too??
How about I but rape you. With your permission of course lol and we will see who the sissy is
Ok we're not friends
Dude if I knew trainman was your bitch, I would have left him alone!!!
Met him a few times good guy old enough to be my pops so I show him respect. I don't throw the bitch word around a lot and I suggest you do the same
