PERFORMANCE MODIFICTION QUESTIONS ANSWERED HERE
gen III with 1000 rwhp and stock internals................I would have to see it , our ring lands wouldn't take very much over 700 for long, especially being pounded on, and 28k for an engine build? man I gotta go up;)
Well...I think it was more like 22K... I got kinda excited there for a minute. lol;)
1000 HP in a 3500 lb car and 1000 HP in 5500 lb truck are the difference. There are dozens of Turbo builds in Texas that are 1000+ HP on Gen3 and 4 and live. Our Texas Mile and upcoming 2k14 event is full of them. Now how long they last I don't know, but they do hold power and I've seen them run the times back to back to back all weekend including dozens of Mexico runs. These are guys that have the money to replace the block if it shits too. As mentioned detonation is the key! 1degree to much timing, loss of fuel pressure/volume , lost spark and a few seconds of detonation will kill it quickly. Avoid those factors and you're good but again...how long? Detonation is basically a fast harmonic vibration and it vibrates the piston rings and ring lands as well, in turn destroying the pistons or worse that broke piston jams and send a rod through your block. Again these guys have money to burn and simply swapping a block is nothing to them. The old " you gotta pay to play" rule. :D
I have heard arguments from both sides on the stock internal thing. I live right down the street from Arrow Racing. Dales says my motor will eventually come apart from the Paxton alone... it's only a matter of time. But than again I think he's lining me up for a $28,000 engine rebuild (screw that!!!! I'll rebuild it myself before I give money away)
On the other hand a buddy of mine from Texas has a twin turbo set up on his Viper.. stock internals, tune dyno blah blah blah. Well over a thousand HP and runs the Texas mile stuff for the past 2 years. He just pounds that thing and it has never failed.
So what's the big deal with a 50-75 shot of NOS?
Let's not forget about water/meth injection on supercharged engines... kinda doing the same thing as the NOS. That's permitable...? correct
Truly, the Paxton was the biggest disappointment for the money. I could of just put 150-175 shot of nitrous on demand with a press of a button for less than a thousand bucks. Additionally I'll take filling a bottle over the constant slipping belt, pressure leaks and full time engine wear.
Making that kinda power in a viper is different then making it in our trucks. The extra weight of our trucks puts more stress on our engines. This is the reason there are More 700-800hp
vipers with stock internals.
What are your thoughts on the NOS with the 5lbs Paxton? I know the end result may be boom but if detonation can be avoided we are only talking maybe around 600rwh in the end.
I know this was directed at Tony but ill give you my take. Do it! It's better than meth at cooling while providing a lil boost in power. Any form of boost creates heat and that combined with an off tune are the killers. Bringing boost/nitrous in too soon is also a killer. Not much different to internals than riding in 6th gear at 40 mph and trying to accelerate uphill with 87 octane. Bring the boost and nitrous in during the powerband Of the engine and make power and do it safely. Our Mini Progressive controllers let you tailor the nitrous hit as well as the timing and length of hit so it also increases the safety factor.
Monitoring of fuel pressure, timing and retard by PCM under wot, A/F, are crucial to longevity as well. Catch a problem early and save your engine. :wavey:
Don't copy me again...you hear? ;)
Well, I think the main problem for me will be the timing. Since I'm running the Paxton "canned" tune I plan on running a few step cooler plug and 110 unleaded octane to try to keep the detonation in check. This would just be used in short bursts by a button and only a 50HP hit to start.
Well the truck "is what it is" (I hate using that term) a big fat pig with a big motor.. pointless but I love it. It will only be so fast like it or not.
I do need to check out the controller.
I wouldn't use nitrous any other way. It's technology that's awesome!
I'm from the ole school squeeze a button nitrous setup, but no longer would I ever do that again. I've heard if buttons sticking many times! That sux, although I never had that issue personally. A nitrous controller is a no brainer IMO! It's a must IMO! Most setup use only WOT switch to activate nitrous which is simple and works, but when you can adjust the specific RPM, hit, ramping of hit and even control of other accessories or a 2nd stage of nitrous as well ;):burnout:
Damn Scott now you got me scared. I call mine a daily driver, but it's more like every other day or so, it hardly ever goes into boost unless I meet a ricer at the red light, but now you got me scared and I'm considering ripping this thing out. I don't have that kind of cash to throw into forged internals, much less rebuilding the motor.
with the Paxton or the roe, do a couple things
ditch the crappy fuel systems, install a good high pressure pump like aeromotive
change out the injectors, drop the plugs a couple heat ranges
get a good dyno tune, let it max out safely, then have your tuner drop it back a couple degrees
running around with it making all it can make is foolish, you may loose a few ponies but your still safe
add meth, but after the tune, don't tune it with the meth, do your tune then add meth, that way its used as it should be , a safety precaution,
keep an eye on the belts so forth and you can have miles of good fun with extra hp
those that go and want that extra "10", those will eventually have a few problems
Sorry bro, my post wasnt to scare you, yet inform you on bad scenarios. Like you said, you're not boosting all day every day so you're gonna be fine. I agree to have tune checked and have gauges to monitor your engine's fuel, a/f, and boost and you'll be good. It's just not something you install and never monitor or keep eyes on. It's the best form if boost outside turbo so I have faith you'll be fine. Especially at 5lbs. That's always the problem is the inexpensive price of pulley swaps for more boost...then pow! Greed is usually what does these engines in. " just a couple more lbs of boost won't hurt" lmfao:burnout:
That's another thing I've been reading up on, install seems very simple, and I've seen a lot of debate on washer fluid versus the snow juice. I've also read about people using their washer fluid reservoir as the holding tank, what's the mileage of that scenario? Would I be looking at filling that up every other day? Week? Month?
Washer reservoir is great for meth storage and should provide weeks of use but again, that depends on how often you boost to the actuation point of the meth. How long have you been boosted? Miles?
The supercharger was on it when I purchased it. I've put 34K miles on it, its reading 60800 miles right now.
Gen 1 hp upgrades
Can someone give me some advice on what I can do to get more up out of a. 04 srt10??
