I don't have any pictures but after a bunch of research without getting anywhere I am pretty sure I figured out the A/C lines today.
At first thought my plan was to order some aluminum fuel line, which I did do btw.. But then as I started researching the fuel line is only tested to 20-30 pounds depending on what brand.. etc etc.. And after more research I found out that it didn't have enough wall thickness as compared to what my A/C lines had.
Then tried to special order tubing to match, with no luck without a wait. I decided to start cutting up my original tubing, and I was able to straighten out the tubing enough and piece in a mid section and get it tig welded back together so I think it should work out just fine.. I have never actually done something like this but I don't see any reason why it won't work. I still have the fittings for charging and the original fasteners, the tubing is just a little shorter now.... Keeping A/C was a priority so glad that is figured out now.. Just have to get a charge when I get things back together and see what happens.
