Ronnie's NA Build
Discussion in 'Dyno Stuff' started by rottenronnie, Jun 13, 2016.
  1. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I've been trying to resist the temptation. :D
    I can't go with much of a shot however. I'm using a glassy-smooth bore finish with a tight end-gap and a wide LSA roller.
    And I'm already using the coldest plug I can get without getting into the ice-cold NASCAR plugs which are Gerschtunken for street use.
    IOW it wasn't built for Nitrous.
    I think a 100 shot would be a semi-safe max unless I tear into again (and I'm too lazy) :)
    But if I pull the trigger, I can sure give you a shout.
    Thanks!
  2. oldcolt
    oldcolt Striker Heads and Cam Supporting Member
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    Ronnie wants NOS :mad::mad:
    :D:D:D
  3. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    That's enough out of you !!!
  4. SANTEEN
    SANTEEN Active Member Supporting Member
    6,150
    May 25, 2009
    Miami, Fl
    Get the juice!!
    Sent from my SM-N930T using Tapatalk
  5. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    NOBODY on this site is allowed to call Nitrous: "NOS" as it is right off the set of Fast & Furious and is fucked up. :chain:
    :D
  6. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    Oh, you caught the ricer sarcasm!! :p:p
  7. SRT2SLOW
    4,372
    15
    Mar 27, 2010
    Green Cove Springs, FL
    What plugs are you using??
  8. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I'm using the coldest Iridium that NGK makes with a 1.04" reach (for the Strikers).
    LFR7A-IX
    The other option: R7437-8 are $50.00 each and are designed for extended high r.p.m. use and are not a street plug.
    The Iridiums can be tricky to gap with that tiny pin of a firing-tip but so far, so good.
  9. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I did!!! :p
  10. SRT2SLOW
    4,372
    15
    Mar 27, 2010
    What would be one step colder from the oe plugs.
  11. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Çhampion's numbering system would have a colder plug than the RC 12 ECC as an RC 11 ECC (if they even exist).
    NGK's numbering system is the reverse. A colder plug uses a higher reference number.
    I'd check with Champion to see what they recommend.
    If you want to switch brands, numbering systems tell only part of the story. A 12 from NGK might not actually be one range colder than an 11 from Champion.
    Clear as mud??
  12. SRT2SLOW
    4,372
    15
    Mar 27, 2010
    Yes sir. Thanks.
  13. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    How about spray, squeeze and juice? Are those acceptable terms? :D
  14. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I believe "fucked up" is totally appropriate/acceptable but the other terms are definitely NOT. :D:p:D
  15. SRT2SLOW
    4,372
    15
    Mar 27, 2010
    Wait. Are you still talking about cars?
  16. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    I can tell you love nitrous.....
  17. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    :D:D:D:D:D Ya, Toadaleee
  18. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Might be fun for sure.
    I'll see what it does at a sea-level track first!:burnout:
  19. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    5800ft DA at my house today. Headed for the coast on Wednesday.:burnout::burnout:
  20. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    Use the white truck to tow the black truck to the track and go and have some fun.
    Bolt on your Drag Radials, drop the pressure to 7 psi.
    Hold the revs right at 6000, dump the clutch and hang on.
    You should have a wicked 60 foot and if it is still around at that point, keep shifting and wait for another 9 seconds or so until you roar through the traps with a big smile on your face.
    Have fun.
