SrtBrad
Michel Productions
- Joined
- Feb 10, 2007
- Messages
- 12,873
- Reaction score
- 17
Well regardless, I hope you don't mind me using it.
No need to ask bro.
Yes, we do need a track day.
I'm going to have to either use some lower front wheels and tires (like Oldcolt suggested) to match the OD of the drag radials or make some passes with the regular setup (street tires).
The height difference between the DRs and the stock setup in the front (with the antilock brake sensors working) , REALLY confused the automatic transmission and it would shift up and down during a pass near the 1000 foot mark.
You guys should do a track day in Mission BC (Vancouver Canada) and I might consider heading out to do video for my fellow snowbacks!
http://www.youtube.com/watch?v=oV0Ys836GD0
That is awesome information to have! Thank you!
The shift points (software) are set at 6450 WOT, that is correct. It will buzz higher than that but it works fine where it is and has good recovery between shifts.
I guess I could have them send me a printout of the pull or grab one next time i am down there.
What did you want to know..something about the power band?
Ronnie, When I redid my motor with Clevite main bearings they also had a larger oil slot in the bearing, is this like the Gen 4 bearing?
speaking of roadracing
i had a baffled pan, swinging pickup and crank scrapper on my big block Charger. was planning on doing some amatuer road racing. was thinking of doing the same with the 10. will a basically stock motor (bolt ons only) survive under the oil sloshing left and right??
I'm curious about the 13:1 A/F ratio on the tune by Chris. Good for power on pump, how about detonation concerns? Have the piston tops been treated or addressed for "hot spots"? Do the Striker heads improve combustion efficiency dramatically to allow for a leaner tune?
Just curious. I like the combination here :rock:
Thanks
The trucks won't create nearly the lateral g-force of the viper cars, however that was a common failure on the cars in long, sweeping turns. I don't think it would be a problem on the truck, but I also wouldn't bet my engine's life on it either.
You guys should do a track day in Mission BC (Vancouver Canada) and I might consider heading out to do video for my fellow snowbacks! Video Link: http://www.youtube.com/watch?v=oV0Ys836GD0
Good time at the Edmonton track a week or so ago.
A couple of brave souls in their Mercedes AMGs running (mid-13s) and a Jeep SRT-8 doing the same. A best of 13.55 for the modded Jeep SRT-8 so...not a lot of air around.
I like using the SRT-8 Jeeps as a gauge as wheel spin for them isn't much of an issue.
But that's high altitude for ya...kicks the crap out of power production.
Still muggy from months of rain..
Density Altitude was 3600 feet. when we were racing.
I had a string of mid 12s with my truck at and around 110 m.p.h.
A few street tire passes too..
One was a 3.0201 60 foot that generated a 14.65 at 108 MPH so it has an "ambitious" top-end charge. That was interesting; and then we drove to Red Deer and STILL managed 14.99 miles per (Imperial) gallon.. Funny shit..
Hope it doesn't rain in Mission at their sea-level track. I would really like to nail down a high 11 the way it sits, before the snow flies around here. We are already down to single digits at night!
Race Weight: 5597 pounds
**Error on my cam specs in original post (this thread) 226/228 @ .050" is wrong. It is actually 234/236 @ .050" (if anybody cares)
Maybe talk to Justin about a 100 shot over the Winter..
