Misterhemi03
Less is better also. I put in 5 oz for 23 gal and mileage went up almost 2 mpg and then i used 3 oz, and my mpg went down. Im gonna fool around with it a lil more.
ntw0rk said:Nice! Thanks Rotten!
droptail said:flyingLow,
I mixed the acetone in a 1 gal fuel jug full of fuel first. Then pured into full tank.
Klean-Strip happens to be the brand I had on hand.
droptail said:What are the results guys? I have (2) mileage adders testing so I can't pinpoint acetone just yet. I have switched to Chevron for my fuel source as I'm told its among the best and consistant. It is a PITA trying to be consistant, not jumping on it much/ the same as usual. I guess it will take a little time to get some good results. Keep us posted.
HOT RAM said:What ratio are you currently using ?
droptail said:I went to buy more Klean-Strip brand acetone from Home Depot where I got the other, and noticed the 100% notice was gone, all the other labeling was the same. I picked it up anyway and called the number listed when I got home. Tech guy said they can no longer market as 100% cause its 95%, same exact formula as years before. So I found a local automotive paint supply store who carries 100% pure virgin acetone in gals, and bought it. Its suppossed to be pure as they have cautioned, so I'm back to a full tank. I have been open tracking over the weekend so I clost 2 tanks of testing. I'll repost the results when I run dry. I expect good results. I believe there was indications of improved mileage for me already with the other stuff. Try to get some automotive 100% acetone if you can.
rreinicherr said:I just bought Kleen - Strip from Home Depot. That stinks that they changed their mixture. I am currently trying 5 oz Acetone, 5 oz Xylene, & 5 oz RP Two Stroke Oil all premixed with gas in a gallon jug. I read where this is good for mileage and extra safety in case of bad gas out of the pump. No results yet.
Why don't you just fill it up @ 1/2 a tank? Add 2 oz oil if you want. I missed the reason for the oil?rreinicherr said:I must have misread the e-mail I received on the mixture. No wonder I did not even get a little jump in the computer MPG readout. Thanks for the clarification.I did put it in a full tank and the RP was a synthetic race oil. I will still hand calculate it at the end of this tank. Then I will try 1/2 of the Acetone and Xylene I just used.
I don't see what is so special about the Torco GP-7? None of the boat racers I know run it? I figured as long as it was a good two stroke synthetic it shouldn't really matter. Although I could be wrong on this too.
Do you think you could run 89 octane with the Xylene?
