Any Questions?
Discussion in 'General Discussion' started by rottenronnie, Mar 13, 2023.
Car Parts
  1. 05 Red
    05 Red New Member
    18
    11
    Oct 10, 2022
    True, but what if you put in some billet internals and a HD TC ?
    Isn't that what some of the high HP 1500 owners have been doing for years ?
  2. ViperPete
    ViperPete Full Access Member
    2,660
    14
    Aug 4, 2010
    Ocala, FL
    Anyone have an idea how many SRT10's are still out there? Non parted/ wrecked trucks?
  3. HemiLonestar
    HemiLonestar Member Staff Member Super Moderator
    57
    48
    Dec 31, 2009
    MD
    No, they either have spare trannies on hand or switch to something else; traditionally a 46RH (A518) or 46RE (3rd gens anyway). More recently the 8HP70 has become doable. After 2013 the 8HP70 was factory available and easily retrofitted in earlier 4th gens. There's a reason the regular RFE was never put in front of the 10 (any version of it) or diesels (the RFE had been around 1999). The exception to this is the 68RFE, and that was a mutant far beyond it's siblings.
  4. Maxville
    Maxville Member
    22
    28
    Mar 6, 2021
    Does somebody know if there is a equivalent injector which will work as a replacent?
    Does the Hemi units flow at the same rate?
    I do really have a problem here in Germany to find a fitting injector...
    Many thanks!
  5. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Siemens Deka makes a "replacement injector" that is 61 lbs.
    The only issue is they are 3/8 of an inch shorter than oem and create some fuel wash as the spray turns to liquid fuel. That is because the firing tip is now up inside a well instead of flush with the end of it.
    If you go with the Siemens above, you will need a retune.
    I have these in my own engine as it's current power level more than maxes out the stock injectors.
    They will also work in a stock engine.
    JMB performance and powercoat sells them. They pop right in and accept the stock electrical connector. I believe Roe still sells them too.
    There are some fakes on ebay and other sites that are junk.
    I don't know of a stock length replacement injector.
    I had the existing injector holes drilled deeper (as well as the fuel-rail pedestals lowered), to prevent the Siemen's 30-degree spray pattern from hitting the sides of the stock-length injector wells.
    This will prevent gobs of liquid fuel (that don't burn) from entering the combustion chamber, and provide more complete combustion.
    Maxville likes this.
  6. Viper Truck Registry
    Viper Truck Registry Well-Known Member Staff Member Administrator Supporting Member
    36,753
    347
    Idaho
    Who wants to take over the Admin duties, I think it might be time to call it a day, week, year, decade+
    Contact @Shaggy
  7. HemiLonestar
    57
    48
    Dec 31, 2009
    MD
    I'm betting I can't see any of that stuff because I'm just a mod and not admin.
  8. Michael from the U.K.
    Michael from the U.K. Member Supporting Member
    327
    11
    May 22, 2006
    Berkshire in England
    Think these will fit an ‘04 Reg cab?
  9. HemiLonestar
    57
    48
    Dec 31, 2009
    MD
    The arms themselves are different but the bushings should be the same.
    Michael from the U.K. likes this.
  10. Michael from the U.K.
    327
    11
    May 22, 2006
    Thanks,I’ll give them a go
  11. Michael from the U.K.
    327
    11
    May 22, 2006
    Thanks man,perfect fit
    HemiLonestar likes this.
  12. THEWELSHM
    THEWELSHM Well-Known Member Supporting Member
    2,434
    45
    Aug 29, 2008
    Brandon Florida
    HEAT Mate
    thewelshm
  13. Michael from the U.K.
    327
    11
    May 22, 2006
    You are correct sir,bust a finger nail with a hammer,dam thing wouldn’t budge,but a minute with the blow lamp and a couple of taps with the hammer and we’re off.
  14. AMS3
    AMS3 Well-Known Member
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    I have a question. I was thinking of a muffler delete, would it take away from the torque or horsepower?
  15. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    No, but a retune would be a good idea and will help rebalance the A/F ratio.
    AMS3 likes this.
  16. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    Thanks for the info Ronnie. So would I have to let Torrie know that I removed the mufflers to do a custom tune, or would a canned tune from him be sufficient?
  17. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    It should be similar to removing cats, as far as tuning tweaks are concerned.
    I'd think a canned tune would work fine.
    AMS3 likes this.
  18. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    Thanks for the info!
  19. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    No charge.
    AMS3 likes this.
  20. Michael from the U.K.
    327
    11
    May 22, 2006
    Topped up the clutch fluid today,wtf is the femidom thing in the reservoir ?
    Cant believe this is the first time if checked the fluid in 18 years of ownership,there’s hardly any room for fluid.
