The heads are stage 4 ported heads from Rolling Thunderz with a complete valvetrain replacement and a valve job by Mesa Balancing.
blackviper said:The heads are stage 4 ported heads from Rolling Thunderz with a complete valvetrain replacement and a valve job by Mesa Balancing.
did you change your guides too? stainless valves? And what did you bump your compression down to? You engines gonna put out some killer #'s!
My head work would not allow the Roe 10 lb pulley to get to full boost. I only get about 8 lbs...Sean felt it was because of the heads flowing so well...I did not have them on a flow bench...but the guy that did them has been doing Viper heads for a long time
what is stock CR? Mine was dropped a bit.blackviper said:Prof, we're expecting the same. Anywhere between a 2 to 4 pound loss in boost. This is why we decided to set the compression at 9.5 to 1 to make sure we are not using boost to offset cylinder volume. Most here have lowered their compression ratios on their builds and have ended up with less or the same power because their compressors cannot keep up.
:needpics:blackviper said:I'm getting excited. The short block is assembled. The heads should be finshed this coming Monday and hopefully the intercooler by the end of next week. Mickey(1qksrt) better be ready, I'm coming over with a truck load of goodies.
GADodgetech said::needpics:
blackviper said:Thanks Robert for the correction. How's your build coming along?
1qksrt said:There will be alot of pics and vids in the next couple of weeks,
My friend Chris and I even were contemplating doing a live web cast of the install,but that got way to technical for me![]()
