faslane505
i need a wet nap
Will the DashDaq read/display/log the stock O2 sensors for the driver and passenger banks? If it does, is there a reason to use the Autometer ones?blackviper said:Here are the pics of the setup. Not quite done but you can get an idea. The 6 Innovate LC1s and 2 Autometer widebands will be hooked up to the Dashdaq. I will be moving the two gauges from the steering column pod and mounting the Autometer widebands there. My day got cut short so I will be finishing the install next weekend.
Put me on the list, great job.eddie102870 said:you need a co-pilot to monitor your guages. like Roy said very clean install.
blackviper said:It will log them but the stock O2s will only give you voltage as a measurement. They will not give you AFR.
So what all will it display? and what does it do?
