ViperPunk said:how do you bump up the compression :dontknow:
pull heads off and shave them down
bump it to around 10.1 or so , not much higher or you will have to run race fuel constantly,ViperPunk said:so what would i bump it to and do i just do that when i get them p.p and say bump up the compression:dontknow:
yessirIronhead said:stink find out how much needs to be shaved to get them numbers ,,,
you forgot to burpStinker said:yessir![]()
its the ice creamViperPunk said:your guys are too kewwwl thanks for the help im definitely glad i started this thread
ViperPunk said:thats crazy so when i have the p.p. just put new gold gaskets on there and it bumps the compression? is that a certain brand of gasket oh and if you could explain how that works im super interested
shhhhhhhhhhsshhshshshshhhhhhh you cant have my strikers:argh: :argh:rottenronnie said:If your heads haven't been off yet, you will still have the old black head gaskets. You will hit 10:1 just by changing to the newer (gold colored) head gaskets without any other machining.
Don't listen to Stinker about NOT NEEDING the Strikers. He has had them in boxes for so long now he forgets what they will do for these engines.
Out of the box, they will KILL any ported o.e.m. head you want to put them against. This of course is comparing TRUE flow numbers.
PS Put some of them on and run 10.5:1 with Pump Gas......(I do...)
Ronnie
Stinker said:shhhhhhhhhhsshhshshshshhhhhhh you cant have my strikers:argh: :argh:![]()
what u want a picture?rottenronnie said:/Fine then, be that way......![]()
:argh: :argh:
But remember they really should be ON an engine instead of in boxes...:slug: :slug:![]()
:burnout:
Stinker said:what u want a picture?![]()
give me a couple minutes since I know the punk would like to see strikers, the ones ya jsut cant get anymorerottenronnie said:Sure, as long as it is a picture of the Strikers....
PS The JTS Venom Performance stickers are in a good place....thanks!
