the ONLY reason any of the engines let loose is the folks that push for the extra 10hp, let it make what it makes with a great tune, and be happy, 7 more hp isn't gonna get you laid quicker or beat the lambo next to you.
it really doesn't matter if its turbos, a roe blower, a Paxton supercharger, or a procharger, the engines have very thin ringlands thus can only handle so much boost with bad tuning on a stock bottom end.
tuning is the key to survival of these engines, but too much of anything and the rods and bearings will start to cave.
so is it particular to the roe? no,many paxtons, nitrous , and sts's have laid waste to pistons and rods, is it most popular ? yes, easy install , cool looks so forth, and ton of instant boost on the street.
why haven't many laid down good numbers at the track? no telling honestly, the power is there but comes on hard down low, most blow off the tires.
a good time will come from a roe soon im sure, many are going the extra mile lately
the roe is awesome for the street, the Paxton procharger is better at the track, which do you spend most of your time at?
either way plan your build, all the components make up the package, and by all means get your build dyno tuned, that is a MUST. it is the key to long life,
DO NOT let yourself get caught up in the dyno numbers game, 600 rwhp can sometimes beat 1000hp, its more in traction setup so forth. The dyno is a tuning device,
hell do what most do, make your number, if its 600 , hell tellem 900, nobody is going to believe either anyway:rofl:
See.......
I said the same thing using fewer words.
I would only add, if one buy the STS, they should know that a box of matches is cheaper and will provide the same result
I do wish ROE could provide the same look as the unit provided for the Vipers. I really don't like the way the intake is attached to the twin screw. Or the loo for that matter. Too many square edges
