spdrcrj said:
No pinched wires Stink. I took Ron's advice and I lowered the intake while my partner watched for anything that could get in the way of a good seal. I currently have the valve cover off, everything looks good. Gonna take come pushrods out to make sure they are not bent at all and re-torque the rockers. After that, will run to autozone to get the plug tester like you guys suggest. Think the motor is ok to run on "limp mode"? I have no other vehicles.
I wouldnt, if the injectors are open you would wash the cylinders and bearings down with fuel . has ya buddy got a ride?
if you cant go anywhere, take a 6-8 inch screw driver
(oh crap Jim is really gonna love this)
stick the end of the driver in the plug boot, then hold it about a 1/8th inch from a ground, have your friend turn over the engine, you should here the "pop" or see the arc of the wire.
oh , guess you should wear gloves tooLOLOLOL
Think about it like you would your job Jim, I have spoken with you many times, and you really impress me on how you do things:rock:
So step back , go over every step , one by one remembering what you did, double check and triple check slowly.
go over al th wires once again, you could miss something even on the third look
If all this seems to check out , like ronnie says, you may need to get a way to the store, get a compression checker and check for leakdown, jsut dont see that tho, I really think you are jsut excited, and pissed, and are overlooking something
Geez Ronnie, uh sounds like we have done this huh?
