was in deep study
this day wether or not to keep the LPG installation...
1) the actual one with evaporators can be used but should be doubled
every dealer tells you their brand is sufficient for the stock 500 HP but it
isn't.Calculating the max evaporator flow they can produce and the max
flow the injectors can give results in clear figures : not enough ! far not
enough to produce around 700 HP...
Ok, a double system can be done but will be alot of wiring and equipment.
2) Other alternative is injecting liquid LPG instead of evaporating it first ( with
warm water circuit engine ) ... haha ! this could be the way to go... i
would have 2 great advantages : the evaporating heat it takes now in the
inlet only cools my air to denser mixture... not calculated but could be the
extra heat from blower taken away ... and LPG has octane 110 ... so sure
good against detonation ... cannot flash VEC3 as for race gas because
must still run on pump gas to...
Inquired fabricators if they have such systems that would work for 700 HP
now must go to dentist ( yes i'm getting old
) , so , again perhaps a evening of not much ROE install work...damned.
