monday evening...started Roe job...just random works as demounting the stock air filter, throttle body .... broke one of those plastic clips , the one on throttle cable
i will have to drive on cruise control
Hope our Dodge dealer has those... perhaps also on other Dodges ? :dontknow: And the cable has a welded? pressed? end to keep the plastic thing... will i have to demount the thottle cable to slip a new one over ??? :dontknow:
Start to demount the LPG installation... my god, this is complex... 10 rubber hoses from jets to injectors , 10 injectors with their electric connections, each side a bank of 3 and 2 , each a rubber hose , coming together in a bigger hose, big hoses from each side coming over 2 filters together and again in 2 hoses to 2 evaporators...Now this is clear visible... my god, the electric circuit... each side 5 plugs and 1 common , 2 computers.... must have cut at least 30 tie strips
before everything was loose... had to cut 3 x the hoses as i was afraid damage the fuel lines wiring , just not even able to see the LPG injectors...
Hope i can finish this tomorrow.... and hope more there's still all original wiring and connections... i hope they plugged in the LPG system and not cut some cables to make intersections with that computer system...Strange but as today it was not clear for me what is original and what is aftermarket LPG build on....
So not a big day... rather a bit discouraged
but as always , tomorrow is another day , :rock:
