The stock rockers are 1.5-1 . Are the Harlands 1.7-1 ? And would that help performance any by going to a 1.7 roller?
O.e.m. rockers are also 1.7.
Strikers will be available again shortly (In answer to your email). They come with shaft-mounted custom roller rockers that work ONLY with the Strikers. I.O.W. the Harlands won't work with them.
Roller rockers are easier on valve guides because they reduce side-loading, reduce overall friction, etc; but any power increase would be slight. In back-to-back dyno testing, I've never seen ANY power increases... Are they better than a non-roller tip rocker? Sure if they are built properly to start with, full roller rockers are a better design overall.
The stock Gen III Viper engines use rollers rockers, just not in the tip.
If you buy aftermarket roller-rockers, make sure your builder checks their alignment because I think some of the manufacturers have been hiring the blind to check them before they're shipped.
Hardened pushrods (also come with Strikers) will offer a bit of a power gain as they resist flexing at higher r.p.m.
As is the case in most performance engines, "weak" pushrods are a cheap fail-safe for the factories when buzzing a stock high-performance engine to stratospheric levels.
P.S.
Is it snowing up there yet?
Ronnie
