Update:
Everything went good, just not as high a result as I was expecting. Let me explain. After the first dyno session when the oil pressure was dropping above 5000 rpm, they checked inside the valve covers and found condensation. There was also some concern (from Greg Good) about the Jesel lifters and the needed modification. The engine was disassembled, heads pulled, and it was discovered that there was a hot spot between the valves where the valve seats were siamesed at their closest point because of the large intake valve. There was also about a 15% leakdown starting. It was decided to reduce the intake valve slightly from 2.18 down to 2.125, that way the valve seats would not touch each other. The reduction in valve size cost about 2-3 % power loss on the higher end, but the engine should live much longer. The external oil pump and lifter modifications worked perfect, oil pressure was a steady 67-68 lbs through the whole dyno run. We tested with 91 octane fuel and then tried MS100 (100 octane) with virtually no difference in power. Chris Jensen was not there, but was helping by phone and computer link, but no real tuning adjustments were made. We did have to raise the rev limiter though. Brad will be posting pictures of the external oil pump and the dyno graph and numbers later. Since the engine had the factory cast flywheel (Exotics not mine) they did not want to exceed 6300 rpm , which is about peak HP as it was only rising by about 3 hp from 6200 to 6300. I have an Aluminum flywheel and we will probably set the rev limiter to about 6800 once the engine is installed. I plan on shifting at around 6500 unless fine tuning moves that up a bit with more timing.
Here are the final numbers: 862.2 hp @ 6300, 787.1 lb-ft @ 5000
Chris Jensen will be able to do more fine tuning once the engine is installed and on the chassis dyno. I will do a comparison of the first dyno runs with the 2.18 intake and the final numbers for comparison in the next post.
