Got this today from Kevin, explains the 3 above pictures. I'm not sure if any coating is being considered.
Hello Jerry,
I spoke to Jaime this morning. The block is in the machine for align bore and hone. He will complete that process today. Then he has to break down from the machine, disassemble and clean the block for install of the cam bearings (cam tunnel is already cut).
The photos I have attached show:
Piston - Gen 4 top configuration with valve pockets, lateral gas ports, small dish pocket to maintain our compression target.
Valve Cover 3D Model - The white portion in the photo below the valve cover mock-up is a 3D plastic model that represents the final CNC spacer program that will be cut in aluminum. This is required to gain clearance between the valve cover and the rockers. (see next photo)
Valve Cover Rail - This is your new valve cover. If you look at the rail, they have placed the sheet metal shell inside the rail which has compounded the clearance problem. CNC spacers will cure the problem. We have made a set prior for another project but we wanted to go back and tune up the design and reduce the overall height.
Once I receive the block, we will finish hone the cylinders and check the deck relationship to the liners. Its common that we will have to make one finish cut on the deck after all of the other machine work is complete. After that we are starting to assemble. I think its a little bit early to start making schedules for the dyno. Let me get the block back in hand first.
Regards,
Kevin Singleton
