bigike
Prof said:You financed a hot rod...with oil at under $40, and you work in the oil industry?
Payment went down 300 dollars per month!!!!!!!!!!!!!!!!!!!!
And Singapore is begging for me
Need that oil at 60 though
Stinker said:Ike be careful bo, anyone can quote you anything, its the details of the build that count and what goes inside.
and they cant guarantee 1000 hp 1500hp, or even 12 hp on a build, they can say its good for that hp, but dont mean you will make it
but I know David well, and what he is paying for motors, and 7500 good for 1000hp and "installed"? uh, thats a littel out there
but if so, jsut remember, you get what you pay for, if ya got a ten dollar head, buy a ten dollar helmet.
bigike said:Payment went down 300 dollars per month!!!!!!!!!!!!!!!!!!!!
rods and pistons want get you an engine good for 1000hpbigike said:I guessed on the 1000hp
but I though it was good for 1000hp with pistons and rods................
If a stock engine is supposed to be good for 700.
said when you get into the bullet proof bottom end that build goes to 10000. with the install being 2000.
Stinker said:......
lets talk motors, post up what you think needs to go into a good reliable motor build and why.
Prof said:I think all of us would be more comfortable with oil stabilized in the $60 - 70 range.
Stinker said:later today I am gonna quote love this truck a price on a short block with good pistons and billet mains a bullet proof bottom end, we shall see what his price comes up to be
i got a few things to do for a bit, but if you want I will even post it, but thats up to you brohanLoveThisTruck said::marchmellow: :marchmellow: :marchmellow:
Stinker said:i got a few things to do for a bit, but if you want I will even post it, but thats up to you brohan
TNVIPER said:is there a core exchange Tony?
yes, that is using your block, and getting your block back.TNVIPER said:I reread your post.....I may have misunderstood it...I was thinking you included a block in your pricing...you actually using the customer's block..right?
Stinker said:here ya go, jsut so everyone knows
and one of the reasons my deal may be cheaper than some others is basically
I WANT YOU BUSINESS! they may not stay like this forever
so my parts pricing is actually really low, i cant do a thing on the machining, its basically outta my hands.
and you will get what you pay for:rock: not finding one day when you open your engine up that you have eagle rods instead of oliver rods
but this is what you get for a short block( no heads or headwork)
bore and hone block
parallell deck block
align bore and finish hone for billet mains
balance assembly
assembly
acid wash
inspect crank
file fit rings
K1 rods(good for 1200hp)
wiseco pistons skirts coated w/rings, pins, locks
billet mains
arp billet main studs
bearings, rods and mains, both coated
gaskets
CC $8970 cash, check $8860
Pricing does not include shipping , install, removal.
also, most all engines will recieve a 1/2 overbore, most of the cylinders on the aluminum engines are found to not be perfectly round, so the better the seal, an overbore is automatically done.
thats a basic standard hardcore bottem end rebuild.
as before there is options such as oliver rods, ati dampners, cams, springs, lifters so on, those can be quoted seperatly.
One thing i do reccomend for longevity is an ATI dampner, and head studs if you plan on forced induction or a large shot of giggle juice
and out of courtesy , please dont ask me to do ten different quotes on differetn things
comp cams around $550
springs around $175
Vavles around $400 new manley race valves
ati dampner I thinkk they were $590- $600
cloyes true roller timing chain i think about $265
extrude hone intake $800
head studs $420
dyers rods i think were around...$2600?
harland sharp rockers , opps forgot the price
hardened push rods $160
Rings for Nos, add $100
above pricing may be flexible, they are CC pricing on some, some are stone , some are not.
one thing to remember if you ever go with a rod such as oliver or some other small block chevy deal, an xtra fee for machining the crank to small block chevy journal sizes will appply.
and also, you need to know what you are going to do with the engine, forced induction, nos, N/A, it makes a difference in the compression ratio and rings.
and since I got with a coating company here close by ,i can also coat the valves, the combustion chambers, headers, crank weights, rods, and so on, but dont have pricing on those as of yet.
