Not really, you might pick up a bit. Cam: yes, Heads: yes, Spray: yes, Supercharger: yes, turbo's: yes. You will need tuning for those mods.
Yeah I already have a monster I cant drive I just want the srt to smoke my buddy's Z06!
what year z06?
what is the best exhaust to but on it??? before I buy something and all you guys tell me its JUNK lol
I just want to go with a cat back??
Volant .. Is it really that bad?
Check out all of the vendors on this forum before you buy. They all own, drive & work on these trucks every day. Ask their advice. When you get ready for the SCT, you can get the unit with the tunes installed from Torrie. Since you are on the East Coast he is your best bet. Take baby steps with buying things for your 10. Remember everyone has an option about what is best, because that is usually what is on their 10 & it has worked well for them. I think we all agree about the K&N, you will not be adding horsepower with the others, but you will be adding bling. Don't jump in the deep end too quickly, it may be money wasted.
wow i really looked around and seen a lot of good about it made the most HP out of all of them... That sucks!
It only has 2k on it.. Thats way i was thinking the air system i got would be best always pulling air from outside??
The hood vent was designed to reduce lift at high speed, and for engine bay cooling when sitting still. It does not work very well as an air intake........maybe at very high speed it might.
What makes it so made it seemed to make the most hp out of them all, and is pulling outside air in?
Will it add any HP
I would like not to buy it twice.![]()
It was bc of you I got on this, I was just googling the questions I had then I seen what you had to say seemed like you know alot about my truck.. But Im going to run that cold air kit I got, I like the looks of it and Im going to run with it for now. I have not put it on yet, I will let you know what I think lol that that you care. But anyways, Thanks for all the help I will post pics soon.Sure it will.... SITTING STILL ON A DYNO. All the dynamics change once your over 40 m.p.h.
Your STOCK system does pull outside air. The grill block off has a duct placed on the upper right side in a high pressure area. Feeds the air into a cavity inside the front fender. Air slows down and recovers some positive pressure and then the engine draws off that into the stock box.
The hood vent is very effective in multiple ways. It sits just below the airstream when moving creating a low pressure area (Draw). As oldcolt stated, it minimizes the "parachute" effect under the hood, allowing the front splitter to be more effective. This draw also allows hot engine air to be vented at any speed above 40 m.p.h.
YES
It does not pull in outside air from the hood when moving. Keep in mind it has two other holes in the box which creates a "through flow" really. This is not a true "isolated cold air feed with slight pressure". It does create low restriction when sitting still on a dyno however. That is all defeated once up to speed. Members like Trainman have modified the box to take air directly in from the front grill. Feeds cold air, just not high volume air. His numbers are impressive primarily because he is an EXCELLENT driver and his overall mods work well as a package!!:rock:
It will if you obtain a wideband A/F meter. You can then fine tune your safe rich canned tune down into the 12.7:1 range. Canned tune can be as fat as 11:1. So can your stock tune. Or just get a custom dyno tune.
Get a B&B. Use it, enjoy it, then sell it later for 1/2 of what you paid or more depending on condition.
B&B
Cheers!
Im going to change the fluid in my tranny like you did, It shifts like shit with the miles you would think it would be mint. Not so much!
