well no tools available that i know of to do this, tried hitting the stud ends with hammer to break them apart but no go, don't know if i can put the wheels back on it to get it to a shop with one spring completely removed. i wouldn't drive it i would have it towed
i guess i'm getting too old for this stuff, didn't have any problems doing the complete suspension on my 66 Charger 13 years ago, and i had never done any suspension work before in my life. i just don't understand why this truck hates me so much.
1.front wheel bearings were toast after i drove it home from CT
2.bed cover supposed to take 2 wks, took 6 wks
3.new hood supposed to take 8 weeks, took 12 weeks
4.took 2 days to get right combo of tools and get intake completely off
5.bolt spinning on under engine pan, can't remove it
6.battery re-location kit didn't fit my truck bed right
7.removed rear suspension to get battery tray in properly
8.cant get lowering blocks to sit completely flat on axle perch
9.whole day shot getting shock bolts loose
10.cant separate tie-rods or ball joints
11.got new yellow plug wires dirty putting them back in
12. scratched up header coating installing them
13.melted taillight lens trying to remove them to modify taillights
14.1 fog light didn't re-seal right so now i have to replace the LEDs in it
15.tires are gonna need replacing if i ever get the truck back running again
16.found a crushed brake line on rear axle, don't know when that happened
17.pass axle seal leaking on E-brake pads
18.Daytona wing i got doesn't sit right for some reason
19.tried learning to weld again, still can't figure it out, wasted money and time
20.wonder what will be next???
still have to work on:
1.install intake
2.install injectors
3.install intake sensors
4.install oil cooler lines
5.install new throttle body
6.install underdrive pulley
7.paint/install new hood
8.install lowering springs
9.seperate ball joint/tie-rod
10.re-install ball joint/tie-rod
11.install exhaust cats
12.install exhaust cut-outs
13.install mid pipes
14.powdercoat wheels and fang center caps
15.open up fresh air hood and paint hood
16.install upgraded shifter
17.install lighted start button
18.install bump steer kit
19.get alignment
20.install traction bars
ok, rant over for now, just frustrated, thanks for taking the time to read this far
just hate being old, rickety and slow
