LATEST UPDATE
First I want to thank 1fast400 for the info:rock:
DTS ran into a problem with the axles and the Baer brakes, seems as though if he was to turn the axles to work with the Baers that the 14mm studs would not have enough meat to be safe.
So in order for safety, DTS did some deaper investigating and called Wilwood direct and conversed with them.
So it comes out that the Wilwood rep says the brake kit with the parke brake will handle 15 inch rims
So I made the decision for them to go ahead with the Wilwoods, I figured thats what everyone would want anyway. Pllus the wilwood is a much better brake than the Baer ,being the Bear is only a single piston and the wilwood is dual.
I hope this is ok with everyone.
The tubes and housings are done, the shock mounts jsut came in.And they are close to finishing our first axle set up, which will go on our illustrious grand puba's truck Prof:rock:
I want to thank everyone for giving me the opportunity to handle this, and their $.
there is a difference in price, but it will be handled.
Once again thanks, and hopefully it will nnot be too much longer.
I would like to remind Fstjack, turbofreak , and Nowwhat that they should decide on a delivery point if they want.
Jack may possibly be able to set up a 3 way conversation to make it easier.
