Hey Randy I will be there Friday and my son will be there with the Jeep. Hope to see you there. Hope I don't look like a ass out there.
heat up those drag radials & leave on the last yellow..... have a blast.HV SRT said:Hey Randy I will be there Friday and my son will be there with the Jeep. Hope to see you there. Hope I don't look like a ass out there.
LoveThisTruck said:Has anybody tried this pulley with a 10lb pulley on the ROE?
TNVIPER said:I am doing a dyno tune Tuesday with the Roe 5.6 pulley and Stinker's crank pulley...the combo puts out 11...I might just try the 10LB pulley while I am on the dyno...just need to figure out the right belt...
LoveThisTruck said:You think it would spin the blower too fast? I know there's a certain RPM Sean says not to exceed:dontknow:
TNVIPER said:Dont know...maybe I better run that by Sean first...:dontknow:
Yellow venom said:If I recall isn't Blackviper with his intercooler setup running that set up,I think its around 15psi of boost?? (with the 10 on the ROE and the 7 on the crank.
blackviper said:Stinker's lower pulley is actually 6.75 inches in diameter at the belt surface area and I'm using a 2.6 inch diameter pulley to start.
LoveThisTruck said:So has anybody done this lower pulley with a 10# upper on the Roe yet?
I will be going this route soon, and need to figure out what belt to get. Thanks
tnviper hasLoveThisTruck said:So has anybody done this lower pulley with a 10# upper on the Roe yet?
Stinker said:tnviper has
TNVIPER said:Dont know of anyone doing the 10LB combo yet...I have a 10LB pulley and had thought about it but after having to install bigger injectors and a fuel pump booster with the 5.6LB pulley (puts out 11 LBs with Stinker's pulley) I decided against it.....I am barely getting enough fuel with both those mods (booster & injectors)....
I would bet you will need to upgrade the whole fuel system from the pump to the injectors...probably a $2K+ mod..
yessir kinda slow tonightTNVIPER said:Never did Tony..changed my mind...see post before yours..![]()
