TNVIPER said:Got the MAP sensor re-routed....truck runs fine until the boost guage reads anything above zero...then it falls on it's face....A/F guage reads 10.0 which is as low as it will go....I am not sure whether the engine stumbles because fuel goes so rich or it is actually going lean but the guage doesnt react fast enough....I dont hold the pedal down because if it is going way lean it might kaboom!!
Probably going to need a temp tune from Torrie till I can get with him and tune it......
Anyone else run into this after moving the MAP from the box on top of the blower to the a line connected to the lower intake?
From my experience,you will have to go back to a base ROE tune,whats happening is in the tune you have now,there was so much fuel added because the map wasn't reading boost,so now its reading boost and over fueling hard which can wash out rings,10.0 is super fat,try a base tune for the ROE and then you will have to fine tune after,thats what I'm going through now.
