Wow very rude. Now if your truck breaks I will be charging you for the flatbed to tators.
You can't use STFU, unless ur part of the elite group. The "STFU, choke-a-bith tribe" Come to Panama and I'll get u in the club. Plus, we could use another boosted QC, to whoop up on those RC bitches.Rickspeed said:Please do me a favor and STFU!!!
REPOMAN1 said:Is that rick?
VIPER said:hahahahahaaaaa..... where rick at ?, did he figure out his truck problem ?
Rocky did he splice the Wires ??? to extend them for the sensors ??
Ramchargerguy said:Was it you that had the problem with #1 spark plug gap? Maybe recheck the plugs, did you change them to the 1 step colder ones?
The only thing that sticks out a little, are those intake air temps, seems a bit high. Even on a hot day, i'm around 125-130 at idle and around 115 - 120, while driving. Your meth is setup and working properly, correct? If so, have you tried playing with the meth setting. Could it be bogging because you got too much meth coming in?Rickspeed said:Ok, I tried every procedure on the forum regarding an idle/running rough situation.
TPS reads 19.6 at idle, and 88.9 at wot
Took it for a 10+ mile ride after resetting PCM and TPS. These are the numbers I am getting after the ride with the truck sitting at idle. Can anyone see anything wrong? I got all these numbers with my kal-tech OBD 2 scan tool. Thanks.
abslt tps (%) 19.6
calc load (%) 3.5
coolant 176 degrees
engine rpm between 740-770
iat 156 degrees
ign adv (deg) 16
lt fl trm1 (%) 31.3
lt ft trm2 (%) 14.8
map ("hg) 7.4
SANTEEN said:The only thing that sticks out a little, are those intake air temps, seems a bit high. Even on a hot day, i'm around 125-130 at idle and around 115 - 120, while driving. Your meth is setup and working properly, correct? If so, have you tried playing with the meth setting. Could it be bogging because you got too much meth coming in?
Rickspeed said:Running champion platinum 7034 gapped at .035
Do you have the little black relay boost box thingy? Ill look for the instructions. But you may have to email sean.VIPER said:Roe w/m kit
lt fl trm1 (%) 31.3
lt ft trm2 (%) 14.8
