jsandlin
apparently the starter isnt the easiest part to remove on the truck. ill have it out in a few minutes though. praying its bad.
jsandlin said:apparently the starter isnt the easiest part to remove on the truck. ill have it out in a few minutes though. praying its bad.
SANTEEN said:Maybe a dumb question. But, have u tried turning the engine by hand with a wrench on the crankshaft?
Prof said:Before you go any further...pull the dip stick and get your wife (or someone with sensitive fingers...to rub the oil between her fingers and see if there are any metal filings in the oil...if the answer is yes...that will say a lot.
Just have to believe you have seized a piston...and it will probably be #3.
Prof said:I hate saying things like this...but, if you have blown the engine...you may have punched a hole in the water jacket some where...is your radiator full or is it down on fluid...maybe even empty?
That would indicate you have a window...due to a rod punching a hole somewhere.
Damn, I hate all these negative thoughts...
Maybe this is just a bad dream.
Well take it to him jackassFahrenheit said:Hey Justin I have a shallow socket that will fit our crankshaft bolts here at the house.....I used it to turn mine to get the TC bolts out....I have 2 different sizes
