BecauseRacetruck
What's is votw
Vipers of the World
What's is votw
I would take them off and shove them up Mopar's ass for false advertising. You should be able to trust what they claim.
I thought the Strikers were available again?
Posted Feb 17th on VOTW:
"Now taking orders on Striker Street, Striker-Rs and Custom Grind Billet Cams..
Ronnie"
If you made it this far, thanks for reading! You can send your $1 to me anytime.![]()
Porting the lower intake and a camshaft change can get you another 50-70whp without spending a fortune on it (not that you want to spend more money on it), the heads flow great, but without a matching cam they arent even close to hitting their potential. Despite the #'s im sure youll enjoy it when you get it back.
Justin
HERE IS THE PROBLEM!!! One of two things have happened to the Viper Truck engines during assembly and I believe Ronnie has already figured it out but it's his research that discovered it and he keeps it somewhat secret and I can't blame him!
I personally believe the truck engines were either installed with the cam retarded ( by timing chain adjustment) or the camshafts themselves were ground a bit different to help get emission approval where the Viper car didn't need to meet that in certain areas. I believe it had something to do with the gas guzzler taxes on engines of this caliber.:dontknow:
Car is about 25whp higher than a RC truck BUT is spinning a lighter 19" vs a 22" wheel, and has a taller rear gear. Both of those things combined easily make up the 25whp difference on a chassis dyno.
That pretty much kills the idea that the trucks all came with the cams retarded (I know that there was an '06 QC or two that did have this problem though).
It also makes me wonder why we don't all switch to lighter wheels for the street.
Something is not right. The gen iv. Head is the best head out there, the have more technology in them than other viper head and when ported and polished and set up will outflow any head out there. You need someone with some experience with the gen 4 head and conversions to get that running right for you.
I say you prove what you have spoken??? My money is on the Strikers!!! Rotten Ronnie already proved that and his mark he has now is a tip of the iceberg to come.
More proof is right around the corner on another set of Strikers!!
Ill get ya some flow numbers, on the heads,,, and the numbers on a couple na builds ...
ill call the shop tomorrow to see if they can get me something..
was the Mopar advertised horsepower gains flywheel or at the dirt???
